Sa250
发表于 2022-6-16 15:51:55 | 显示全部楼层 |阅读模式
I’m looking to buy my first sa250d is there anything in particular I should keep an eye out for When looking at it this weekend
Reply:I have not own a SA250.But buying a generator I look at the brush slip rings. Then engine oil and water and wiring. I would also look at the reactor to see if over heated.Dave
Reply:Look to see if there is any cracking on the frame or motor mounts. I've heard that they are good machines but vibrate a little too much at idle. The 3 cyl. Perkins engine is outstanding though. I have one in my 1965 tractor and it's the most reliable machine I own. Weld with it and try all gears (coarse adjustment) and adjust the fine current control up and down on the control panel. See how the idler works and try the 115 volt plug. You need an AC/DC grinder or something similar because I think it's DC current only at the plug. Using it should tell you if it's a good machine. Look for smoke and listen for odd sounds while you try it out. Unless the temperature is freezing, it should start right up with no glow plugs or starting fluid.Last edited by Welder Dave; 11 Hours Ago at 04:26 PM.
Reply:I agree.When DC welder I had buy everything AC DC. There are tools today that are not made for DC. Maybe ad a belt drive AC generator.Or do like did bring a AC generator to job too.Dave
Reply:Thank y’all so much for the advice
Reply:I own a SA 250 with the Perkins 3 cylinder diesel. They do have considerable vibration at an idle, but they are some of the smoothest machines I’ve ever used. Typically very smooth even at very low amps. The one I have does have ac outlets. I read the other folks comments. They all sound like good advice.
GMT+8, 2025-12-18 08:57 , Processed in 0.094674 second(s), 18 queries .
