Sp200 transformer voltage
发表于 2022-6-16 15:51:54 | 显示全部楼层 |阅读模式
have had my SP200 for years and now the control transformer is bad, cannot find anywhere what the x3 and x4 voltage out to control board should be. Plenty of user manuals out there but no repair manuals or specs for this transformer and of course its painted orange with no numbers on it. Here is what i verified to get there. Power to breaker box verified, power through breaker to plug verified, power to incoming welder contactor verified. Verified contactor is good(coil actuates with external 120 power and ohms good when actuated) but will not actuate from control voltage. Only have 40 volts off of control power taps x1 and x2.
Reply:Sounds like winding X1-X2 might be open and you’re seeing40 volts there because X2 and X3 are joined at the circuit board. Can you disconnect wires to X1 and X2 and either check winding for continuity or power up transformer andcheck winding for voltage? (Tape up disconnected wires)Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:If it proves impossible to find an exact replacement transformer and X3-x4 still works on old one , maybe add a small 240/120 control transformer.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Derived from the wiring diagram note N.A., X1/X2 voltage should be 115VAC.Many Lincoln machine control voltage is typically 24VAC and per the troubleshooting information trigger voltage from the control board is in fact 24VAC.  Based on that I'd guess Control Transformer X3/X4 output to be 24VAC as well or perhaps as much as 32VAC.A phone call to Lincoln Customer Service may just get the information you need.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:I did remove the wires from the circuit and get x1 42vac to ground x2 42vac to ground x3 32 vac to ground and x4 31 vac to ground from the transformer with it powered up. Ohmed out I got 1.5 on x3, x4 and 7.2 on x1 and x2. And nothing to ground or between the two circuits x1,x2 and x3,x4. I thought about adding a small transformer like you stated but I don't know what the voltage on x3,x4 should be is the roughly 30vac correct or an effect of the bad x1,x2 120 vac circuit not working correctly? Probably just cut the side off the transformer and count the windings. It isn't working anyway lol! Little bit of formulating will get me the voltage I need then I can spec out a replacement.
Reply:thank you duaneb55!!! I must have missed the 24vac in the documentation, where was that stated?
Reply:Based on your 40VAC reading from X1//X2, I presume the cooling fan doesn't run or at best spins very slowly.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Troubleshooting item 6, "What to Do" line d. on manual page 14.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:That is correct, the fan or main power contactor  does not come on.
Reply:I would have to conclude X1/X2 winding is compromised and X3/X4 are fine.Can you confirm the fan operating voltage via a data tag?  If in fact 115VAC, applying same to wires #31/32 when disconnected from the control transformer should make the unit operate if all else is OK.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
GMT+8, 2025-12-18 09:25 , Processed in 0.089607 second(s), 18 queries .
