Smoker build question
发表于 2022-6-16 15:51:53 | 显示全部楼层 |阅读模式
I’m going to build an off set smoker, and I’ve got an old air compressor tank that 14”x24” that I’m going to use for the fire box. I’ve found an old diesel tank that is 19” wide by 36” long. My first question is this; do y’all think 19” is to narrow for a cooking surface? I’m planning on cooking just one piece of meat at a time, so the the biggest piece of meat would be either a rack of ribs, or a brisket. The next question and MOST importantly is, IF I’m able to secure this old diesel tank, how would you go about ensuring any and all diesel particles, fumes, and residue is removed so that it’s safe to cook with. Thank you in advance. 😀
Reply:19” is big enough. The some tragers are that diameter and hold a brisket
my cooler is 19 deep I believe
Originally Posted by 52 Ford
I'm hate to tell you this, but...... the stove pipe on your smoker is crooked.
Might wanna have yer levels checked.
Sent from my Lincoln Buzzbox using Tapatalk
GMT+8, 2025-12-18 09:29 , Processed in 0.060122 second(s), 18 queries .
