Stainless welding gray
发表于 2022-6-16 15:51:52 | 显示全部楼层 |阅读模式
If i use .045 308l rods my weld is shiny but when i use 1/6 308l  my welds are gray. Heat zone seems the same. I tried more and less amp but no change
Reply:Could also be that you are cooking out the nickel and Chromium with too much heat? i.e., moving too slowly with the 1/16th rod? Maybe you need more amps so you can move out quicker.Miller Multimatic 255
GMT+8, 2025-12-17 10:55 , Processed in 0.334443 second(s), 18 queries .
