Ramps
发表于 2022-6-12 15:51:32 | 显示全部楼层 |阅读模式
Summer WorkPeterbilt fifth wheel ramps.
Reply:You have a very serious problem.You welded everything in upside down! I mean the angle is pitched the wrong way, the air bags are install on top, and the axle is on the very top? How does that work ....Haha
Originally Posted by jniolon
Reply:Your sure those air bags won't rub on the dogleg coming down behind them when they compress?The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
GMT+8, 2025-12-17 11:07 , Processed in 0.152539 second(s), 18 queries .
