Shop Made Tools
发表于 2022-6-12 15:51:31 | 显示全部楼层 |阅读模式
So... shop made tools. Whatcha got? Post some pictures. I've been sick the past few days and felt too crappy to work in the shop. Next time I'm out there, I'll try and dig up some of my shop made tools and take some pictures. I'm counting customized tools in the "shop made" category, too.
Reply:I made this anvil!  weighs 340 lbs.  the florida oak stump is a mother 100!  I cut it out of a "hammer" from a concrete crusher, the hammer weighs about 900 lbs.  This steel is similar to Hadfield Manganese, so it had to be cut with a Carbon arc gouger.  I preheated and welded it with some real expensive rods and peened each bead or it would crack. I have damn near 100 hours mainly due live never done this... And prolly never will!   Customers that come into the shop love it.
Last edited by welding1; 20 Hours Ago at 07:03 AM.Reason: grammer.We've done so much, for so long, with so little. Were now qualified to do anything with nothing !
Reply:Here are a couple threads along that line:https://weldingweb.com/vbb/threads/7...highlight=toolHere are some threads on other sites:https://www.jalopyjournal.com/forum/...ipment.235784/https://www.hotrodders.com/threads/s...y-them.196767/https://www.race-dezert.com/forum/th...2/#post1299333https://www.garagejournal.com/forum/...thread.209475/This one has several items made from members of WeldingWebhttps://www.homemadetools.net/categoriesMillermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Reply:This is one of the favourites I made. Adjustable oxy-fuel torch holder with gas line quick disconnects and square stem for 1.25” vertical receivers or hardie holes. Here it is on my home made anvil shaped object …
Sent from my iPad using Tapatalk
Reply:home made ASO easily relocated with pallet jack..
Sent from my iPhone using Tapatalk
Reply:Not worried about breaking that one?The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Originally Posted by Lis2323
I'm just a lightweight so no worries there
Reply:Here's another link for you.... few in there that I've posted on this site as well....https://www.thecombineforum.com/thre...t-tools.40149/The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Originally Posted by psacustomcreations
Keep eating those muffins and you might go up a weight class.
. Sent from my SM-G996U using Tapatalk
Originally Posted by 52 Ford
I like it! Whatcha make the top out of?For a right handed smith, you want the horn on the left side. Might wanna flip it around so you don't get made fun of.
Sent from my Lincoln Buzzbox using Tapatalk
Reply:Ohhh. I figured you added a plate to the top. That's some SERIOUS flange thickness.You wanna hear my 2 cents on how you could improve that ASO to be the BEST dang anvil that never was?Sent from my Lincoln Buzzbox using Tapatalk
you mean i have a choice?
but seriously,sure. just keep in mind I have REAL anvils and it is nice having this hunk of iron to do cold beating/straightening on. Sent from my iPhone using Tapatalk
Add webbing between the base and the top plate (flanges) to stiffen it up. Cut some clearance under the heel, add a Pritchel hole adjacent to the Hardie hole, taper the horn out to about a 3/8" point, and TURN THE ANVIL AROUND. People are gonna take you for one of them left handed weirdos.
As it is, if you use the hot cut you have in the Hardie hole, the off cut would land on the anvil, inevitably bounce off, and land in your shoe. I know that anything I leave on the anvil or anvil stump in my shop ends up falling on my left foot.... always the left foot.Edit: and this is purely my opinion, but I think it would look cooler painted black... maybe Ford blue? Prolly black. OR strip all the paint off it, let it get a light coat of rust, then rust converter, then a liberal amount of boiled linseed oil.Sent from my Lincoln Buzzbox using Tapatalk
Reply:Getting beat up is what ASO's do best...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
heh heh. that hot cut is used as a work stop for when i chip the dross off my plasma cuts.
keep in mind this hunk of iron is only used to be best upon.  I don't do any smithing. best i leave to you guys
Reply:Oh... and it still needs to be painted either black or Ford blue.
Reply:dunno.  35" long. never had to lift it
Here's what you do... get a 36" diameter graduated cylinder. Stick the ASO in it. Fill the graduated cylinder with water (sparkling if you're feeling fancy). Take note of what level the Perrier is sitting at in the graduated cylinder. Remove aforementioned ASO. Now, note how much LESS Perrier there is in the cylinder. That difference is the volume of your ASO. Convert to cubic inches.Now, get out your hacksaw, some files, and a block of 4140. Make the block EXACTLY 1 cubic inch. Feel free to get creative. Doesn't have to be a cube. Just has to displace a exactly 1 cubic inch. Next, take a scale (the one you use to measure your "herbs" with will work fine) and figure out how much that single cubic inch of 4140 that you carved into a set of **** weighs. Now, multiply whatever your **** weighed by the volume of your ASO.It's really that easy.(I don't own a crane scale.)Sent from my Lincoln Buzzbox using Tapatalk
easy peasy lolORI have a 1000# (I think) platform scale I can drop it on but it will need to be weighed WITH the block of wood and fork pockets. Sent from my iPad using TapatalkYea... I was thinking 600 lbs there total.... might even be a little light at that. I do my daily beatings on the home made post anvil I have posted here before. The tool steel top dates back to my grandfather's days and we think it may have come off a 20's HOLT/Cat.
Railroad rail, tie plate, Ford pickup base.
Reply:Milling tooling shop made.Dave
HF 170 welderHF 4x6 band sawSouth Bend 9NMillB&D mag drillVictor torch
Sweet! I'll be honest... you don't need a horn on your anvil for the majority of anvil work... hell, purpose built bladesmithing anvils don't even come with horns. Looks like your anvil is a lot nicer than a LOT of the bladesmithing anvils I've seen...  Interesting color scheme. Come up with that on your own?
Might I suggest you stock up on Old Ford Blue? https://www.tractorsupply.com/tsc/pr...saAhWKEALw_wcBSent from my Lincoln Buzzbox using Tapatalk
GMT+8, 2025-12-18 18:49 , Processed in 0.093317 second(s), 18 queries .
