What are you running for a engine drive welder?
发表于 2022-6-12 15:51:31 | 显示全部楼层 |阅读模式
Lets hear what ya'll are running on your rig and what type of welding you do.  I have a Miller PipePro 400 with a Caterpillar.  I do aluminum dump trucks, tankers, heavy equipment at a mine site, water treatment plant repairs, structural steel repairs, pontoon boats, gates, heavy trailers lite trailer even mail box posts and lots more I cant remember.We've done so much, for so long, with so little. Were now qualified to do anything with nothing !
Reply:MIller Big Blue 502 DI do mostly mining machinery ....dragline buckets and excavator buckets dozer blades whatever else wears out or breaks
Reply:Lincoln 330MPXHeavy SteelLincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunLincoln AC/DC 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc Gouging CAC-AEverlast 62i Plasma CutterIngersoll Rand T-30 14hpInstagram: #Freebird Welds
Reply:This ain't my rig... but here's a lawn mower with a PTO welder on it
Sent from my Lincoln Buzzbox using Tapatalk
Reply:I had Miller gasoline driven stick welder before sold my business. Today if need for portable welder it would a generator and my wire welder Dave
Reply:That stuff sounds like wayyyyyyyyyyyyyyyyyyyyyyyyyy too much work.www.urkafarms.com
Reply:Miller AEAD
Sent from my iPad using Tapatalk
Reply:Denyo DLW-400LSW. Single stick to 390A or dual stick to 195A. Remotes for welding current. Four 100V single phase outlets for the tools. 15kVA 3ph generator that runs any other gear I want to use (MIG, TIG, Plasma). 100% duty. Kubota Tier 3 diesel. Super quiet.Panasonic YC-300BP2Panasonic YC-200BL3Suzukid Arcway 180Lincoln Idealarc R3R-400Thermal Dynamics Cutmaster 52Everlast Power i-MIG 230iEverlast PowerArc 300STDenyo DLW-400LSW...and other assorted garbage
Originally Posted by Lis2323
Miller AEAD
Reply:The car hood might have been from a chevelle. The previous owner hinged it so that he could service the engine which I’m quite certain he never ever did. Can’t expect much for $150cdn. (delivered) although it had 150ft of 1/0 leads ..…….Sent from my iPad using Tapatalk:
The car hood might have been from a chevelle. The previous owner hinged it so that he could service the engine which I’m quite certain he never ever did. Sent from my iPad using Tapatalk
Originally Posted by 52 Ford
Oohhhh LOLYou buy it from this guy?
The leads are worth the $150!I think 1/0 is like $3 a foot if I was to order it online.Sent from my Lincoln Buzzbox using Tapatalk
Reply:A Miller TB 302 and a 325 with fuel injection. After a long line of SA-200 Lincolns. My field work now is mostly farm equipment and irrigation pipe work. The last heavy bucket work was back in 2014 on a 992 Cat loader, not really missing that stuff now.
and had a new battery and jackstand!and he threw in 4 buckets of cast  iron fence post finials (topped up with water) lolthe guy was a train wreck. came back a few days later and asked if he could borrow the welder for a day to do a job??.I said okay and had to bug him for a week to get it back. he kept making excuses it was too cold to work but he just couldn’t get his *** outta bed. Sent from my iPad using Tapatalk
Reply:I have a little list of them but this is what I usually use,,, its loud, its a gas burner but really has a lot of power.
www.urkafarms.com
Reply:44D , since the photo retrofitted with jenuwine Caddy hubcaps, mostly farm stuff.
Being poor is the most expensive thing there is
Reply:little vintage princess auto special.
Sent from my iPhone using Tapatalk
Reply:Thats bad a$$, id love one or those!We've done so much, for so long, with so little. Were now qualified to do anything with nothing !
Reply:What kind of draglines you servicing Pop? You got the same rig and job as I do. We have an 8750, 2570, 9020 and a pair of 1570's(one unfortunately just got turned off. Damn coal fearing world).
Reply:I remember the ad.Dave
Reply:Much as I love vintage machines, modern is the way to go for efficiency if your livelihood depends on it The Lincoln 305G I had for the farm and backup power for the house….
:Bobcat 225nt from the 90's.Just used it for random repairs for the old farmers that lived in my area - before I had to move.Now I just use it once in a while for a little welding or power for the house.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:An old Hobart GPB-258 with the Willys engine. It's currently getting some TLC in the form of a whole new exhaust system, new plugs, modern spin-on style oil filtering, new fuel filtering and fuel lines, new air filter, and a general clean-up. Oh, and an oil change with a 1/4-turn drain valve.Last edited by nickel_city_fab; 5 Hours Ago at 09:55 PM.Use a bigger hammer.
GMT+8, 2025-12-17 11:07 , Processed in 0.225515 second(s), 18 queries .
