Miller M-180 help needed
发表于 2022-6-8 15:51:35 | 显示全部楼层 |阅读模式
I am restoring a vintage Miller M-180 and disassembled the unit to get it powder coated and didn't take pictures of the internals. Can someone take some pictures of the guts of their machine? I need to reassemble the two rollers and spring that show the amperage adjustment.Thanks in advance for any help you can provide.
Originally Posted by Oldiron2
Why don't you go to the Miler site and try to find a manual with the schematics for your machine, using the serial number to get the right one. I'm not sure lots of other people here have one and can do what you ask, let alone have the time and inclination to open up their machine to get pictures, assuming they even see your thread. For that matter, it might help if you post pictures showing the  faceplate, the general internal location of the parts in question, and what they look like, in case your machine is similar to other models.
There are shop drawings on the miller site but it doesn’t depict the two rollers inside the machine
Most manuals I've seen there have parts breakdown diagrams and parts lists in addition to the electrical schematics. Couldn't find a manual with that? Also, what about the pictures I suggested you post?
Reply:Glad you got it figured out. Have a great day.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Wow that was nice.
Reply:well that was rude
Sent from my iPhone using Tapatalk
Got it figured out. This will be the last post I make on this forum. Your crappy replies aren’t appreciated. I’m not sure if you are a moderator or system admin but you are rude.
Originally Posted by psacustomcreations
Hopefully you come back. Not everyone is rude and even when some are, it doesn't happen too often or it takes a but of prodding for them to get that way.
Reply:Your first post made assumptions about what other members might be willing to do. And it came across more strongly than needed.
Sent from my SM-G996U using Tapatalk
Millermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
GMT+8, 2025-12-17 10:56 , Processed in 0.140632 second(s), 18 queries .
