Low profile benchtop welding rotary table.
发表于 2022-6-8 15:51:34 | 显示全部楼层 |阅读模式
Looking for a bench top positioner rotary table. Motorized. I'm having a really hard time finding something that isn't ~12" high off of the table... to the work plate... Almost like an average record player height and dimensions... Anybody know a company that makes one somthing like this...
Reply:A milling machine rotor table is about 3 to 4" you need to add you own motor.Dave
Reply:I've looked at the indexing rotory tables before, can't really see an easy way of grounding the work, without totally arcing the whole setup. I'd like to not have an additional tool taking up space as of late. I have found an idea of someone who made a potters wheel type of setup to weld with... sounds good and still might go with that... but I'd like just a unit I can broach the product to the boss about...
GMT+8, 2025-12-18 09:29 , Processed in 0.094918 second(s), 18 queries .
