Convert Euro to Miller
发表于 2022-5-31 16:00:05 | 显示全部楼层 |阅读模式
[ATTACH=CONFIG]1739969[/A
TTACHIs there any adaptor I can buy to run this gun on my Millermatic 255? I have seen the machine conversions but do not want to do that. Please provide links if u have them.Thanks in advance
Reply:What brand gun?Do you need to switch the gun back and forth between a Euro equipped machine and the Miller?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:I switched to tweco so all could use same guns and parts.Dave
Reply:Its probably just easier to buy a new gun. What brand of gun is that and why are you trying to substitute it for the MDX gun that came with your MM255?Miller Multimatic 255
Reply:It's not worth messing about with other than to buy one of these style adapters.https://weldingdirect.com/adaptorkits.htmlMurphy's Golden Rule: Whoever has the gold, makes the rules.
Reply:You have to contact Tweco. They have adapters for most welders. Dave
Are u saying Tweco guns will work in a Millermatic?
Don't need to switch back k and forth could be made to work permanently on the Miller if possible. The gun is tregaskiss.
GMT+8, 2025-12-18 10:43 , Processed in 0.113075 second(s), 18 queries .
