查看: 13|回复: 0
Pak master 100XL Plasma Cutter
发表于 2022-5-31 16:00:05 | 显示全部楼层 |阅读模式
I have a Pak Master 100XL, never been used, basically brand new.  I had to replace the circuit board due to a broken switch, got that from the manufacturer from Thermo Dynamics.  Unit will turn on, have good air flow, brand new tip but no arc is produced.  Checked grounding and connections but no arc.  Any ideals on what I need to check.  I have unit hooked up the a 220 outlet.
GMT+8, 2025-12-18 08:56 , Processed in 0.065858 second(s), 18 queries .
