Have a newly acquired Lincoln 225 used welder. Off switch flash upon shut down.
发表于 2022-5-26 15:51:24 | 显示全部楼层 |阅读模式
This machine is very clean and probably not used much. It welds very smoothly as a new one. My concern is when upon shutting it off, I see a flash from under the bottom directly below the switch. Anyone ever have that?
Reply:Probably fairly normal, unless it's huge I wouldn't get wound up about it.
Originally Posted by John T
The switch may be going bad.  I would take it apart and see if you can clean up the contacts etc.  I know yours is a 225,  But here is the backside of an idealarc roundtop.
Reply:Make sure you disconnect it from the power source!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINELET'S GO BRANDON!"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
GMT+8, 2025-12-18 14:20 , Processed in 0.088405 second(s), 18 queries .
