Red d arc gx200 will not weld or have 120v output
发表于 2022-5-23 15:51:43 | 显示全部楼层 |阅读模式
Was welding for a couple hours with this machine and it decided to stop working, engine fires and and runs fine. I just have no AC output or welding out put now.I believe I properly checked the 3 capacitors and they are all within 10% of the spec.I’m kinda lost on what to check next. Looking for help
Reply:This might help.  Not much to check for the issue you're having.https://www.red-d-arc.com/pdf/GX200%...e%20Manual.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
GMT+8, 2025-12-18 10:43 , Processed in 0.083026 second(s), 18 queries .
