查看: 14|回复: 0
5p+
发表于 2022-5-19 11:02:58 | 显示全部楼层 |阅读模式
Anyone have experience with Lincoln 5P+ compared to regular 5P? I read the differences on Lincoln's site, but am curious as to what your experience has been. How do they compare and differ?
Reply:I stick with the 5P but that's just me. Mainly because the rod is red and stands out in a sleeve. I've run tons of it and have gotten used to it also. I ran 100lbs of the 5P+ and didn't see a difference. I rarely bench weld or work in a controlled environment if that makes a difference.Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunModified Lincoln 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc GougingEverlast 62i Plasma CutterIngersoll Rand Type 30 14hpInstagram: #Freebird Welds
Reply:Solid answer based on experience. That is what I am looking for. Thank you.
Reply:5p+ runs better on machines that are borderline for having the higher voltage needed to run 6010. It seems a little less aggressive than brick red 6010. I had a can of 1)8" Lincoln 5p+ that didn't run very well because on many of the electrodes the flux would flake off in large pieces.
Reply:I've used both, mostly 5p+ because I bought it cheap and stacked it deep thanks to the Oscar Home Depot deal. Seems like I prefer the 5p+ to 5p although I'm not sure why to tell the truth. Maybe because I got it cheap and have a lot of it. They're pretty similar.
Reply:I've run massive amounts of both and like the + better myself. It is not quite as aggressive as the red and seems to freeze just a little faster which helps when welding 14 ga. purlins and the gaps my helpers some times leave on fence joints.
Reply:Seems to me the 5P rods runs smoother and the Plus P has a more aggressive bite with more sparks burning thru my sleaves...We've done so much, for so long, with so little. Were now qualified to do anything with nothing !
Originally Posted by 123weld
i think u gettin 38 special confused w/ weld rod, cuz i almost say opposite
Originally Posted by 12V71
Yeah, same here. I like the red 5P for roots and the Plus for fill passes.
i totally agree.        were  just halfway playing w/ "welding1 " for fun though
+P .38 special... I caught that.
I like +P 9mm, to each his own.
Originally Posted by 52 Ford
Shoot. I jumped the gun (pun intended
) and replied before I read the rest of the reply.Gotta say, I'm in the .45ACP crowd. Prolly cause my first pistol was in .45You ever seen 9mm +P+? THAT is a hot loading. I think "Buffalo Bore" sells it.Found it: https://www.buffalobore.com/index.ph...t_detail&p=118 500FtLb muzzle energy in a 9mm. Wringing every last drop out of that cartridge.
I can go either way, got a nice Kimber .45 and A Beretta M92 9MM. I like the Beretta because it holds 17 in the mag. +P hollow points all the way. My other 9MM is a Browning High Power, 13 rounds and a good grip feel. My other half carries a Walther PPK .380 and knows how to use it even though she's better with her M1 Garand  rifle.
Reply:I agree that that the  5P 6010 red rod is definitely more aggressive and has lots of sparks.      The 5P+ is a gray colored rod and runs smoother and a lot less sparks, almost like 7018.The Hobart 6010 I used last was a gray rod, and ran like the 5P+.
i ideally like to have both in my pouch to choose from, as our  fitups arent always as consistant/nice as we like.     sometimes i cant justify having a 50lb can of both open.    a fresh can welds so nice.      the way lincoln been going , it wouldnt surprise me if they quit making the red/5p in future
Originally Posted by Ruark
If that red 5P makes more sparks, does that also mean it makes more spatter?
Reply:5P+ is good but is this 5 times better? Oh yeah, you're seeing it right, 5P+++++.
Reply:Only rod pics I have.
www.urkafarms.com
Originally Posted by cwby
That looks like 1109 electrode.
The numbers are upside down. That's 6011 AC Sent from my iPhone using Tapatalk
Reply:They are for running downhill when you do overhead.www.urkafarms.com
Originally Posted by TooNew
do you find the 5p+ is better with larger gaps?
and A Beretta M92 9MM. I like the Beretta because it holds 17 in the mag. +P hollow points all the way. My other 9MM is a Browning High Power, 13 rounds and a good grip feel. ifle.
if im using red on a root/gap, and i switch to grey, to me, its like turning the machine down a couple amps (without having to actually go adjust machine).    so yea to ur question, but difference is so small
the browning is a classic, other is nice too.     but i dont know how the glock 17, can be beat -  pricewise, reliabilty, capacities
Reply:If your welding pipe which is what it sounds like you will have way better luck hot passing and filling with a 7010 like hyp or 85Faster fill freeze than 6010
Originally Posted by John T
I’ve tried the +P in 38 specialsIt was ok, I guess.  Not that much of a difference IMONever tried it in 9mm I know my .380 max does not recommend it.  Too much pressure for a compact. ? .
Ya gotta think, +P is just a higher chamber pressure.
Glocks are good, Myself, I just prefer a single action trigger pull. I do like the fact that the Beretta gives me a choice for the first shot if the chamber is loaded, wipe the safety and go double action by pulling the trigger or **** the hammer and go single action. After being a 1911 guy for years that double action option takes a bit of practice. And yes the Browning is a classic... Mine is Israeli surplus but really shoots good. I think it was pre-trained for me.
GMT+8, 2025-12-18 08:56 , Processed in 0.067805 second(s), 18 queries .
