Can I weld these aluminum grades together?
发表于 2022-5-19 11:02:57 | 显示全部楼层 |阅读模式
Can I weld 6061 to 5052 using 4043 filler? thanks
Reply:Yes. If this is for a salt water application you have to recognize the corrosion rate of two exposed dissimilar metals is much greater than for a single alloy of the same metal. Essentially, the two exposed alloys become a battery in in the presence of salt water.
Reply:The few time I welded aluminum I use chart from welding wire company to find correct wire to use.Dave
GMT+8, 2025-12-18 10:21 , Processed in 0.083623 second(s), 18 queries .
