Miller 225G no 240v at accessoire outlet but have 110v on both 110 outlet
发表于 2022-5-19 11:02:55 | 显示全部楼层 |阅读模式
Hi, I have a 225G miller which don’t produce anymore 240v. I don’t find why, as I have 110 on the two 110 accessories outlets. Anyone have an idea what to look for? What can be the problem?
Reply:More info needed. Accessory outlets should be 120 volt.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:Do you get 240 if you put the meters probes in the "hot" side of each of the 120 outlets?
Reply:Yes someone in pass play with the wiring.Dave
Reply:Is there a fuse or CB for the 240 itself?
Reply:Check for 120V from each 240V hot leg to neutral to see if one or both legs are dead and go from there.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
GMT+8, 2025-12-18 16:51 , Processed in 0.068997 second(s), 18 queries .
