Air Carbon Arc electrodes breaking in class
发表于 2022-5-19 11:02:53 | 显示全部楼层 |阅读模式
I’m about 9 classes in to my first class, Cutting processes. Never welded or cut before. I just got out of our first Air Carbon Arc class, and it was a nightmare, though thankfully I wasn’t the only person messing up. Among other things, we managed to break 6 electrodes. When one of mine broke, it broke more readily than some twigs of the same size would. Obviously she was pretty pissed about all this, so I’d really like to avoid this in the future. Is this normal for these electrodes? I tried googling various ‘CAC-A electrodes breaking’ phrases but didn’t find anything, which suggests that it is not.
Originally Posted by Oldiron2
As is frequently the case, you are asking for answers without giving many details.... including anything specific about who is/what "she" looks like; .
Originally Posted by Lis2323
As usual Oldiron gives good advice.   Let’s start here and see how we can help you.  Sent from my iPad using Tapatalk
Reply:Yea, but that still doesn't tell us what she looks like...lol, and has she offered to buy gas?The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Originally Posted by 12V71
It's a simple case... Carbon rods are super fragile. I break the dang things all the time. You just have to use up the broken pieces as best you can. And I have to buy my own.
Originally Posted by Freebirdwelds
I use 3 empty Lincoln Excalibur 10lb cans to keep the 3 size rods I carry. Even then they are rolled in bubble wrap around the bags they come in.
Reply:Are you maybe tapping them like 7018 rod to start the arc? They are like glass so treat them as such.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Mine carry all right. I just bump them and such when I'm working. Seems like no matter how careful you are...
Reply:I agreeIt is not a welding rod.I have used carbon a few times but quickly learn Dave
Shiit, just the weight of the torch leaning/rolling against it will snap it when you set it down.
Reply:It seems strange that they would give you carbon arc cutting before having you weld.
Reply:If you choke up on the rod it will keep the arc hot and there is less chance of snapping the rod. Leave 4-6" sticking out and move the rod back after you gouge until you end up clamped on the non-coated end. You can't lay the stinger down with the rod still clamped. Its a specialty application, best to treat it as such.Lincoln 275 SquarewaveLincoln SP 250
Reply:Choke up for sure, they run best at about 6" sticking out from the holder,  Those 1/4" rods are so fragile, I prefer 3/8" rods they break less but you need at least a 400 amp machine.We've done so much, for so long, with so little. Were now qualified to do anything with nothing !
Reply:The thread was started 3 days ago with one post, and the OP hasn't been back since.
Reply:I see that a lot on new ones.I guess he is reading the thread. Dave
Originally Posted by Oscar
or two 200A machines in parallel
Originally Posted by Munkul
I've often wondered what the practicalities of pairing two machines for arc-air are, and if there are any downsides.My ideal setup would be one (or two) inverter machines just for arc-air, either a big single 400-500amp unit, or two 250-300 amp units. I would like to run 1/4" carbons at roughly 300-400 amps.So, example: I have a spare Thermal Arc 250TE TIG inverter which is worthless (HF/gas start is broken, but works fine in MMA mode). This is rated at 210amp at 100% DC.If I found another 250 amp inverter... any inverter... would they have to be matched machines? Would it have to be another TA 250TE, to ensure the load is balanced? Or could I get away with pairing with, say, an XMT 300, which is a totally different machine?And then it's just a case of joining cables together, running off our massive 3phase supply, setting each machine to 200 amps to give 400 amps total, and off we go? Have I got that right, or wrong?
Reply:Anybody use scarfing tips these days????????????????????
Reply:I like using the torch and grinder.In 110° Day I do not need to wear a leather coat for gouging. Dave
Anybody use scarfing tips these days????????????????????Those are the cat's meow for washing off track pad bolt heads without damaging the pads.
Reply:Good tip, I might be doing a set, I think I have one somewhere.www.urkafarms.com
Reply:Breaking off their thin twigs and "she's pissed" ?...I just know there is a terrible joke in there somewhere waiting to get out...
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:If your rods are breaking you must be hitting them on something, if your rods are breaking from just having to carry and bring to class ,the easiest way to keep them from breaking is, ask your teacher for the box the rods come in. you must be using or learning with very very small maybe pencil size or smaller rods. everybody at some point breaks rods, I really dont have that problem. I am using 1" rods with a 1500 amp power supply!
Reply:Don't take this the wrong way, but we all would like to see pics or video of your 1" rod in action.
Century buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
Reply:You guys are funny  so funny you'all much really lack in the experience of carbon air arcing. Its one of the things i specialize in.  If your lacking in air arc experience most likely your also lacking in open root welding using copper backing, thats something else i specialize in with stainless, nickel, mild steel, low alloy with over 100 metal alloys. You guys are so funny you probably think im making it up that i have 2 navsea 250-1500 certifications 2 inconel 112t certifications,2 inconel 182 1 of which is navsea and the other being dissimilar metals fabrication a 309 dissimilar metal fabrications certification 12018m hy100 certification, ferralium 255 certification, harris 630 for the ge lm2500 front frame casting  of which i've done 2 production runs 100 each. Still laughing boys ge/ruston lm5000 ge lm6000, 7018, 308 navsea, 316lt-3, 320lr, 410nimo, ok68.55, 958ht-0, you ever thinks thing are so funny,  in order to do my job i had 7 different sizes and shapes of copper because of that 1" carbon rod working on  or out of a 600 degree preheat oven. You want a really good laugh, because im laughing now, repaired and fabricated 6 full ge ship set of trident and ssn 904 propulision systems, sstg-2,  cvnx, westinghouse sunny vale,westinghouse cvn, the west 1 production model, i bet you neverheard of a project call ge ipmp2-improved performance machinery phrase 2, i fabricated  the ge thin wall prototype for ssn seawolf 21. You guys are probably the type of welders that have or had 1 weld booth worked in 5 a week on days or swing, in order for me to get where  i was and specialize in it i had to work in 4-5 different weld booths a night, 20-25 a week. That open root specialized skill of mine is with 5/32 rod or 1/16 dualshield wire, so you might think that 1" carbon rod really is no joke or laughing matter. Heres something  that you might find funny or want to really laugh about, i was the only welder without a hy80 certification, because i didnt have the time? At one point in time i was coming in contact with over 80% of the work cycling thru the re and ue depts either welding or defect cavity arching
Reply:Hey i got a couple question up on weld messages talk board on another site see if you can answer the mismachined post or the mild steel post, the response side stepped the answer most likely because the admin couldnt answer it how many different ways can you fill that mild steel defect cavity , i can do it 6 differen ways with no problem passing rt inspection
Reply:Well we'll aren't we special.
Reply:Yes i am there was no other and i havent work in a foundry in 20 years, your a good indication with that way of responding just another fourm with people  that have welding experience but couldnt pass the 7018 and 316 vertical up on a double vjoint groove  because you lack air arc experience and couldnt arc out the groove the right way. On a 1 1/2 thick test plate, its not really being special its called custom engineered products
Yuh know.......they sell them panties now a days that don't bunch up as easy.....are you really that thin skinned?
Reply:Cvn is aircraft carrier cvnx is nuclear powered aircraft carrier
Reply:Another legend in his ( or her) own mind. WTF does any of this fantasy land BS have to do with someone asking about having issues with air arc carbons breaking? Give it a rest.
I dont wear panties,  from the sounds of it ,there must not be very many "REAL" welders on this fourm. remember you wore diapers before your mommy got you panties. let me be a little more specific for the mr know it all that probably has a lot of .045 or .035 or smaller exp, welded on some pipe somewhere and calls himself a pipewelder. might have some air arc exp with 1/4 rod or smaller, and maybe even had a couple of his welds x-rayed. dont forget somebody most likely got you your job. if not you must of went to school to learn how to weld? did that school teach you how to air arc with 1" carbon rod and 1500 amps on a 20,000lb casting preheated to 600 degrees. did your school teach you how to defect cavity air arc looking for internal rejects up to 12" deep. did your school teach you how to defect cavity air arc looking for the "SLAG"  you buried 3" inside the weld repair. did that school teach you how to due diminsional air arc on a ge lm2500 front frame cast that probably has 14-18 risers on it preheated to 600 degrees.  OH! i forgot you welded on pipe somewhere? I had to do my job with over 100 different metal alloys, for 3 divisions of BINGHAM SULZER, 4 divisions of BRYON JACKSON, 3 divisions of DRESSER RAND,  3 divisions of  WESTINGHOUSE, 4 divisions of BORGWARNER, 4 divisions of FLOWSERVE,  4 divisions of GE, 3 divisions of UNION PUMPS, PACIFIC VALVE, JOY HOOK, WORTHINGTON, BJ HUGHES, GIMPLE, IMO, TARGET ROCK, MAFIA TRENCH, HYDRIL, 3 divisions of GOULD, CEKSB, BOEING, RUSTION GAS, GE EVANDALE/FIAT, HAYWOOD TYLER, LAWRENCE PUMPS, and you probably call yourself a pipewelder. I didnt have the time for PANTIES?
Reply:To the OP.   Hope you found some useful info regarding your dilemma. Not certain how your thread got sidetracked as this rarely happens.
Sincerest apologies from us and hope you continue to hang around. Sent from my iPad using Tapatalk
Originally Posted by mla2ofus
If you're not careful you'll have both arms in a sling due to dislocated shoulders as a result of patting yourself on the back. I'm sure there's no vanity in your family as you seem to have it all.
Reply:Wow and I thought it was bad when I broke my tablet (stone) in spelling classRetired Old GuyHobart 210Lincoln AC/DC 225/125 Tombstone Evolution 14” Saw
GMT+8, 2025-12-18 16:15 , Processed in 0.097247 second(s), 18 queries .
