Lincoln v350 pro with DH-10 feeder running Miller XR aluma pro?
发表于 2022-5-19 11:02:52 | 显示全部楼层 |阅读模式
I’ve had my Lincoln v350 pro with DH-10 feeder for several years and have only really used it for running hard wire and occasionally flux core. I’ve always wanted to be able to run aluminum wire at home and I recently was able to obtain a Miller XR aluma pro push/pull gun. Is there a way I can run this with my current feeder? Adapters? I’ve searched around online and there really isn’t much info on this topic or on my v350 pro in general it seems.
Reply:Your push/pull gun manual should have several ways to hook up to random welding machines.If you need a manual, miller has them free online.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-18 19:15 , Processed in 0.126972 second(s), 18 queries .
