Stel P80 - 70A plasma cutter - 400V / 3-ph
发表于 2022-5-19 11:02:42 | 显示全部楼层 |阅读模式
Don't ask me a bunch of questions! (Ruark, circa April 2022
Look ma'!  Twins!   Shares the same exact case with the S300 stick welder/CAG.
Next up is a CNC machine torch for it.
Reply:Sweet...matching cases makes it easier to build a cart anyway...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Nice look machine.It looks like everything you use is on 400 volts. Odd voltage for America,  Canada or Mexico. Dave
Reply:Yep, I already finished my MIG cart, I just need to get the videos edited and put it together.  I plan to build another cart for my Invertig 221 w/ water cooler, S300 w/ water cooler, Microcut 875sc plasma, Inverarc 200TLP stick welder.   I'm not sure if I'm gonna put the P80 on the cart though, since I plan to use it for a CNC plasma table.  Or I might just put it all on the new cart.
Reply:It is odd to see 50hz 220v for a toaster or hair dryer. Try children sticking a paper clip in that plug. Back around the 1920's LA had 50hz and switch to 60hz. I new someone that had a job of change out the pulley on record players. I read somewhere some countries are going to 110volt 50hz for homes for add safety.  American like 60 hz for electronics and little cheaper on generators.Dave
It is odd because this machine is not meant for the western continents.  It's predominantly meant for the European markets.
Reply:Ok... whole lotta question #1... does it use standard consumables or will they all have to be special ordered from Stel?The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:So with a max. cut of 30 mm, that's just over an inch. That should keep you busy for a while...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
GMT+8, 2025-12-18 16:17 , Processed in 0.072831 second(s), 18 queries .
