Powermax 30xp help. Air but no spark
发表于 2022-5-19 11:02:42 | 显示全部楼层 |阅读模式
I have a 30xp and while using it in my cnc, the torch went out. It shows the flashing consumables light saying the consumables aren't on properly. But they are. Even with new ones it's not working. When the trigger is pressed, air comes out but no spark. Anyone have an idea what's going on?
Reply:Triple check your consumables. make sure cap is not to tight.Then call Hypertherm tech support.You will not have to test the power pcb. See if you have buss voltage.it is possible the inverter in down and pilot IGBT has failed. Or torch is open.Torch can be checked with an ohm meter. You can get all the manuals on hypertherm's web site. If in warranty ask Hypertherm for a service shop location.
Reply:Hello, i"m sorry to hear you are having issues with your 30XP. Please give us a call so we can help troubleshoot. You can call us here: Technical service(800) 643-9878 or you can email us through our website here: https://www.hypertherm.com/en-US/con...ical-questionsRandy, Marketing Data Specialist – Americas RegionHypertherm Inc.
GMT+8, 2025-12-18 16:17 , Processed in 0.091705 second(s), 18 queries .
