7A749 still around?
发表于 2022-5-19 11:02:40 | 显示全部楼层 |阅读模式
Tried sending a PM but his inbox is full. Hoping he’s still around. He was always my go to for my Maxtron 450…Hypertherm PM 1000 on a CNC TableMiller Maxtron 450 - S52A series feederHobart Handler Lincoln 155 (my sons he's 11)looking to sell or Trade a RFC-23A foot pedalCustom diesel parts fabricator
Reply:He's not online really, but he's still alive and kickin.
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I haven't seen anything in a long time. Knowledgeable fellow & a nice guy. His personal life was less than perfect.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:Well glad he’s still kicking around even if not online. If anyone would happen to have an email or number for him I’d appreciate it. I pulled a stupid move with my maxtron and could use some direction. S-52-A wire feeder was acting up and wouldn’t power the motor to feed wire. While searching for the problem stupidly shorted a wire post out against the case of the feeder and shut the whole damn Maxtron down. It won’t even power up now.😭😭😭
Reply:Thank you 😊 Dave
Reply:Check fuse F1.If you don't have the unit manual here's one that shows where F1 is in Section 4-4.https://www.millerwelds.com/files/ow...O2206G_MIL.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Thank you all. 👍🏼👍🏼
Reply:I've sent him a copy of your post describing the problem.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-18 16:22 , Processed in 0.094252 second(s), 18 queries .
