Multimatic 215 TIG/Board Issues
发表于 2022-5-19 11:02:40 | 显示全部楼层 |阅读模式
I've got a multimatic 215 that won't tig weld all the sudden. Its starts the arc fine and welds for between 3 seconds and a minute or so and then stops and gives me MOTOR ERROR the motor has drawn too much current. That is a code for the wire feed motor that is obviously not in use through this process.It does this with or without the pedal. I called miller tech support and the guy said it sounds like a board issue. It's out of warranty so is there anything I can do to diagnose? Thanks guys
GMT+8, 2025-12-18 16:16 , Processed in 0.110143 second(s), 18 queries .
