Restoring Bluestar 2e
发表于 2022-5-19 11:02:40 | 显示全部楼层 |阅读模式
I’m currently working on getting a Bluestar 2e to nice working order. When i disassembled the generator I noticed the tag ends of the fabric used to cover the coil wires on the rotor is starting to lift up next to the bearing end.  Is there an epoxy safe to hold these down for the long term? Or is there a better option?
GMT+8, 2025-12-18 16:18 , Processed in 0.096955 second(s), 18 queries .
