Chop a SA 200
发表于 2022-5-19 11:02:39 | 显示全部楼层 |阅读模式
OK.How small can you chop a sa 200 to?Make in small as possible.either you LIKE BACON or you're WRONG!!!! "There are three kinds of men.The ones that learn by readin'.The few who learn by observation.The rest of them have to pee on the electric fence for themselves"-Will Rogers
Reply:If you swap the engine for one of them Horrible Fright engines and change the generator to a inverter and use light leads you can get it small enough to fit in a Japanese convertible car.One of the MessFit geniuses can help you with the electronics and it'll be able to burn 1/16 rods.Add a thread spool from a sewing machine and call it a gas drive MIG.
Reply:5" is doable with the original fuel tank and would require a custom radiator or sacrificing the battery box.Have seen 8" chops but they require a custom fuel tank in addition to a radiator and/or relocated battery.This was a 5" chop with $500 custom radiator:
Owner started the project and I finished it.
Last edited by duaneb55; 09-22-2018 at 10:24 AM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Is a sweet running machine and owner sold it earlier this year as he now has an SAE300 Perkins and Miller Trailblazer Pro 350 with Kubota D905 I brought back from the dead last year.  Just sent the 300 home the other day after addressing a few things on it for him.Before . . .
. . . after . . .
Dodged the 16+" of Harvey water I had in the shop as she was up on jack stands.
Save Second Base!
. . . after . . .
Reply:Can you show me how you did the gas tank? I’m having trouble with mine
Reply:The machine owner did most of the tank mounting and I just added a couple finishing touches.
Save Second Base!
GMT+8, 2025-12-18 16:28 , Processed in 0.100141 second(s), 18 queries .
