Sa250 shunt coil problem
发表于 2022-5-19 11:02:37 | 显示全部楼层 |阅读模式
I have an sa 250 code #8306 and was pressing out a shunt coil and busted the iron core piece that sits inside the coil. It’s broke bent and pretty chewed up on the side that fits into the housing. The housing is fixable I just need to replace the piece that the coil sits on. Asking for some advice before I try to rebuild it thanks in advance
Reply:A photo would help.It maybe a simple problem but a set photos would show how to replace the part.Dave
Reply:There are a couple vendors for parts I think, Bills Repair maybe?  They might even have used piece.www.urkafarms.com
Reply:Will be a pain to find.You need find someone parting the SA250 and hope they have a good one or repair the one you have.Dave
Reply:Hoping I can straighten it out, clean it up re weld it and if it fits back in Never see it again. Not sure how exact the core needs to be so it might work fine
Reply:Did you press that out or beat it out with a sledge hammer?I agree with Sberry on checking with Bill's Welder Repair or other well known repair/parts vendors for a used piece.  You're dealing with a core-to-armature clearance that the deformation may create a significant problem.A simple fixture and 20T press makes the job much easier and damage free.
MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
GMT+8, 2025-12-18 16:16 , Processed in 0.092386 second(s), 18 queries .
