Added spool gun to welder tested fine now neither will feed
发表于 2022-5-19 11:02:37 | 显示全部楼层 |阅读模式
Added a spool gun to power mig 200 and tested both guns feed wire.  Didn't have any argon gas so could complete testing.  Went back to it a couple of days later and now neither gun will feed.  Im new to this any help would be greatly appreciated.  Thought it might be a fuse but can't locate any inside welder. Jeff
Reply:Check the control voltage it should be around 24 volts.Dave
GMT+8, 2025-12-18 16:16 , Processed in 0.096128 second(s), 18 queries .
