Correct 90 degree fitting for H 190 shielding gas line?
发表于 2022-5-19 11:02:36 | 显示全部楼层 |阅读模式
Is this the correct 90 degree fitting to thread into shielding gas fitting on back of H 190 that stock gas line fitting to screw into?#AW-407, CGA 032 Nut/NIP - 032 Body 90'
Sorry, meant for the pic to be thumbnail I want to put 90 degree elbow on back of H 190 shielding for  gas line and be able to thread the stock/original line fitting into the  elbow.Wanted to double check this is correct fitting. :-) Cheers, Allen
GMT+8, 2025-12-18 16:08 , Processed in 0.088034 second(s), 18 queries .
