WTB used OA spray torch
发表于 2022-5-19 11:02:35 | 显示全部楼层 |阅读模式
I am looking for a used Oxy-Acetylene spray torch for sale. Eutectic seems to have made a lot of these units, and more recently victor has as well. My budget is 100 - 200 for the torch, depending on condition, and number of tips. I may also be interested in the spray powders as well, depending upon what they are.SRA & IWW memberCentury 250 amp AC/DCCentury 295 amp ACCentury High Frequency Box
Reply:What are you trying to spay ?Dave
Reply:Trying to learn to spray, hard to do without a torch!SRA & IWW memberCentury 250 amp AC/DCCentury 295 amp ACCentury High Frequency Box
Reply:Spray does not hold upIf try machine a shaft it may peel off.Some machine shops like as it saves time.I like weld build up then machine never come off. Dave
Reply:I've seen some heavy repairs done with a spray gun, are you sure that it's not just your technique/equipment? Regardless, I'm looking to buy a gun and learn the process.SRA & IWW memberCentury 250 amp AC/DCCentury 295 amp ACCentury High Frequency Box
Reply:Have seen one about a month ago in Craigslist for 450.00.For a new one look at these.http://www.palcoweldingsupply.com/hot.html
Reply:Are you looking to do this type of repair.Tried to search for the gun he was using and could not find it as he is from Australia.
Reply:Are you looking for Hot spray or Cold spray. ? I might be able to help you out. I also have a bunch of powder I might sell. Cast repair and hard surface powders. If you plan to do smaller shaft build up you really need the cold spray process. Hot spray for everything else. I sold this stuff for many years.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
Reply:I plan to do hot spray, I've been watching eutectic torches pop up on eBay for a while, but I would rather buy from someone here.SRA & IWW memberCentury 250 amp AC/DCCentury 295 amp ACCentury High Frequency Box
Reply:The torch he uses in that video is the MSSA 'Puddle Torch' if I am not mistaken. They have a website if you are curious.SRA & IWW memberCentury 250 amp AC/DCCentury 295 amp ACCentury High Frequency Box
Reply:I purchased a used Eutectic torch w/ one tip for 150 USD. Thanks all for looking.SRA & IWW memberCentury 250 amp AC/DCCentury 295 amp ACCentury High Frequency Box
Reply:I have a spray outfit FS with asst. powders  $200 plus shipping   LINK FOR FB LISTING  https://www.facebook.com/marketplace...1342394864339/Bob Fillmore NY
Last edited by doxie; 03-29-2022 at 04:30 PM.Thermal Arc T-Bird 270 Amp gas welder Thermal Arc Pro Wave 185PowerArc 200 Riland 60 PlasmaMiller suitcase 12vs wire feeder, 180 Amp Diesel Welder GenEllis 1600 bandsawImig 205 Mig,Eastwood 250 migLincoln 250 G9 Pro gas Weldanpower
Reply:I purchased one pound of Nickel powder for my spray gun from eutectic. 220 dollars!! I think next time I will buy a partial used container.SRA & IWW memberCentury 250 amp AC/DCCentury 295 amp ACCentury High Frequency Box
Reply:That is down side too.Dave
Reply:You try using mig or flux core it works great too. Dave
GMT+8, 2025-12-18 16:28 , Processed in 0.156157 second(s), 18 queries .
