Wanted. A white faceplate for a miller dial arc
发表于 2022-5-19 11:02:35 | 显示全部楼层 |阅读模式
Hello I am looking for a faceplate for an older miller dial arc 250 ac/dcUsed is fine white would be better but black would workThanks        FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:thanks for the heads up 7a749   but i was thinkin more on the lines of used but not abused.only have 150 in this welder so 100 or better for a faceplate just scares me.   FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:Felonyass MonkThis is the, Straight 'info' No Chaser.Post a Pic.I see hundreds of welding machines a year, in all conditions; I do not purchase/collect weldors, but I am familiar with virtually every vintage machine posted on the WW.Post a Pic, and you will have an expanded resource field beyond collectors and those fluent with model numbers.Opus
Reply:this is the type of faceplate im looking forthanks  Felon
Reply:Take the plate down to your local sign printing shop, that's what I do, the local shop actually prints on the metal, comes out looking amazing.
Reply:Only one problem with that idea,I don't have a faceplate to work from.i had the welder apartFor repair and painting and by the time I got back to it the faceplate had gone south.i have heard rumors that it was used to patch something up but have yet to find the culprit so I can strangle same said!!!!         FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:Oh.  Bummer. Probably on the rusted floor pan of someone's vehicle."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Bump upCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:PaPa  See reply #8     FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:BUMPITY BUMP last try for a used faceplateCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:I am going to try and make a stencil for it I will try and keep you posted on how it comes out.
Reply:If have good photo you go to copy center and have reproduced. I use copy paper and put temper hardboard. Using a clear cote .The biggest problem is finding a clear cote that does not melt the print.Dave
GMT+8, 2025-12-18 16:10 , Processed in 0.111105 second(s), 18 queries .
