Big 40g TW 20
发表于 2022-5-19 11:02:34 | 显示全部楼层 |阅读模式
Well...I have tried to save this welder. It has TW 20 engine.  I have found the generator is bad and can not be fixed. The engine runs well. If anyone has a good generator end with a bad engine, this may be the fix. My number is 651 755 6186. Send me a text message, I will send you photos and video. I need to get $1000 for the welder and trailer it sits on. You can buy the engine but you have to take the whole works out of my driveway. Located in 55089.
Reply:A couple of tips to help you sell this.  First, most of us don't know where zip 55089 is and we probably won't look it up, so you might want to  name a city and state.  Second, a picture or two of what you're trying to sell posted right here is the #1 way to sell it.  I'm sure a moderator can help you upload it if you're unsure how to do that.  A person with only 4 posts here, with at least one of them being a "for sale" post, comes across as a little fishy.  A little time spent on the details will probably get you a sale.
Reply:Thank you tbone550 for the help. 55089 Is Welch, MN. The moderator was very helpful and sent me wiring diagrams I needed. I went through the procedure and found the stator is the issue. I have found there is no place locally that is willing to try to fix the stator. If anyone needs an engine send me a text message, I work odd hours, 651 755 6186.
GMT+8, 2025-12-18 16:10 , Processed in 0.100391 second(s), 18 queries .
