6'x11' 1/2 thick welding table
发表于 2022-5-19 11:02:33 | 显示全部楼层 |阅读模式
Price $500.00Incredible 1/2 steel welding and fabrication table. 6'x11' in size. About 1400 lbs in steel plate top alone.Top is blanchard ground 1/2 plate on 3"X3" legs.Height off the ground is about 30 inches.Top has surface rust after transporting in the rain, but cleans up with a flap disc or cup brush with ease. I cleaned the spot you see in the photos in 10 seconds with a piece of scotch BriteIncredible table, perfect for welding, fixturing, final assembly etc.This was the chassis table for our vehicle builds for years before going to something bigger.Can load on a 6x12 Uhaul trailer, or simply have it picked up on a rollback wrecker for easy loading/unloading.Located in metro west Boston.  (Zip 02481)[email protected] is you have any interest as I don't check in here often
Reply:Wish you were closer. Nice deal. Good Luck.
Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunModified Lincoln 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc GougingEverlast 62i Plasma CutterIngersoll Rand Type 30 14hpInstagram: #Freebird Welds
GMT+8, 2025-12-18 16:22 , Processed in 0.098545 second(s), 18 queries .
