Newbe Needs Help with Fuel Problem on Lincoln Advantage 400 Perkins Engine
发表于 2022-5-19 11:02:32 | 显示全部楼层 |阅读模式
Machine starts and runs for a second then goes to low idle then shuts down. IT will restart and do the same thing. I've changed Both filters and tried again with the same results. Any Ideas?THanksDale
Reply:Year Born, Hours on it.Will it stay idled up if you have something AC~ plugged in and powered up when you start it?Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunModified Lincoln 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc GougingEverlast 62i Plasma CutterIngersoll Rand Type 30 14hpInstagram: #Freebird Welds
Reply:2011  with 4400 hrsI tried that and it will not stay running.
Reply:What inj pump they use?   First thing,,, right off, run,,,, buy a service manual for it.Last edited by Sberry; 1 Week Ago at 01:47 PM.www.urkafarms.com
Reply:When had fuel problems with fuel I would a buy a  new fuel line to can of fuel. This way I know where problem is, most time in old equipment it was the fuel line from tank to the pump or carburetor.  Sometimes it was a rust in tank too.Dave
Reply:Sounds like the low oil  shutdown circuit is kicking in!Stupid question but have you checked the oil level and added if low?
Reply:Could be bad tooBut all the low oil  shutdown circuit that I have seen had led that tells you.Dave
Reply:Change the oil and filter the filter might have a bypass and it might be not working just a guess
Reply:from what I remember, the perkins diesel has a little lever on the lift pump to prime the fuel filter.  Can you work that lever and feel resistance?  Then will the engine start and keep running or does it still go to low idle and quit?  You have a fuel supply line breaking down internally and stopping the fuel from flowing to the lift pump OR the lift pump is bad.
Reply:Could be sucking air on the suction side of the pump.NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINELET'S GO BRANDON!"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
Reply:I had test tank about 1/2 gal that could vise grip above the carburetor and line to the carb. I got a low cost forklift. Then new if was a fuel problem or something else.  The one problem was most hard to find was old forklift.  It had new carburetor,  new coil and all new lines . But the problem was the distributor hard a worn bearing. Replaced the bearing and ran great 👍. Dave
Reply:Dave, it's a perkins diesel...no carb and no electrical distributor.
Reply:I just pointing out in gasoline engines  problems I have had.Most problems I had with diesel was a fuel line or tank problem But point was to a clean tank and line to isolated the problem.  Dave
Reply:OK Dave.  Just thought that you went off on a walkabout.  But yeah, it does sound like a hose problem or junk in the tank
Reply:Some of perkins diesel engines use distributor and one pump, this can make harder to find the problem. I like Cat engines as they use a injector pump for each piston. But do most common problems first the fuel lines and tank.After that I just have the injector pump rebuilt.  Saves time and money.  If Cat they are easier to rebuild in the feild. Dave
GMT+8, 2025-12-18 18:43 , Processed in 0.159649 second(s), 18 queries .
