Have a Lincoln gxt 250 ranger bolted to a small wooden decked aluminum trailer. Suggestions on how to ground the welder either to the trailer or via different method? Not "grounding" to close the circuit and weld, rather "grounding" of the welder frame to prevent shock.
Reply:Run a bonding strap from the GXT 250 over to the metal part of the trailer.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:This from Miller but ya get the idea Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Plus you could add a anti static ground drag strap to the trailer frame.Last edited by Freebirdwelds; 03-28-2022 at 06:18 PM.Reason: SpeelingLincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunModified Lincoln 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc GougingEverlast 62i Plasma CutterIngersoll Rand Type 30 14hpInstagram: #Freebird Welds
"Last edited by Freebirdwelds; 3 Days Ago at 03:18 PM. Reason: Speeling"Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
