Alpha Tig 200x ac issues
发表于 2022-5-19 11:02:31 | 显示全部楼层 |阅读模式
As it says I have a alpha tig 200x. After moving my shop. It wouldn't puddle up aluminum. The arc jumps all around.just nasty. Tried all adj,tungsten, material,. Does fine on DC,. I tested my 220 outlet...L1-110,L2-220, it's a 3P shop.  I have since changed to make sure it's 110 on each. What should I check now? It did great before the move.
GMT+8, 2025-12-18 16:57 , Processed in 0.040893 second(s), 17 queries .
