Welding cable fire
发表于 2022-5-19 11:02:30 | 显示全部楼层 |阅读模式
This lead was included in a small inverter stick welder ,been sitting in my shop couple of years used it yesterday and could of been shop fire, setting EP 115 amp, found out lead is copper coated aluminum, this stuff corrodes to a white powder just from sitting "junk"
Last edited by doxie; 1 Week Ago at 05:40 PM.Thermal Arc T-Bird 270 Amp gas welder Thermal Arc Pro Wave 185PowerArc 200 Riland 60 PlasmaMiller suitcase 12vs wire feeder, 180 Amp Diesel Welder GenEllis 1600 bandsawImig 205 Mig,Eastwood 250 migLincoln 250 G9 Pro gas Weldanpower
Reply:Copper coated aluminum does corrode in humid environments.  Sitting in a garage area lots of stuff stay out of the weather however weather creeps in in the form of oxidation. Glad you didn’t have bigger fireRetired Old GuyHobart 210Lincoln AC/DC 225/125 Tombstone Evolution 14” Saw
Reply:Use only copper flex cables.The copper plate will flake off then down to smaller aluminum wire. Most transformers today on secondary side is aluminum only but on flex and works great. Dave
Reply:Yup, it's garbage.
GMT+8, 2025-12-18 16:51 , Processed in 0.074021 second(s), 18 queries .
