Grinder tongue guard (for OSHA)
发表于 2022-5-19 11:02:30 | 显示全部楼层 |阅读模式
Well, in my long list of repairs for the school, this grinder got written down for lacking the tongue guard (stupid guard).I didn't like the ones I found for sale, tin junk - and like the original on another grinder, they left a large opening (at the top) as they get adjusted down.So really, they don't do the job OSHA requires, but are considered a valid guard just because they are in place.
I decided to make a rolled design that is never in the way of a proper sight-line. (some of the replacements were straight and blocked some vision)I cut wood templates to the correct radii for the inner and outer shoe and rolled to match.(they can't be the same radius)I did the same for the radius on the mount.
The roller leaves very deep marks, but it doesn't slip
I milled the slots before rolling.
Made t-nuts so I only need one wrench to adjust (so lazy...)
OSHA orange
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
They have a full 2" of travel.Turned out good 'nuff
Reply:That's a new one on me!!Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Looks great 👍 Dave
Reply:I wonder what's next for OSHA, completely covering the wheel? I get the tool rest being adjusted up close, but that is insanity.
Well, ...this grinder got written down for lacking the tongue guard (stupid guard) ...).
Reply:We send the grinding  to China it mush safer than doing grinding in America.  Dave
Reply:OSHA probably wanted the circumference of the wheel and brush covered.  Your's seem to only cover the edge of main shield and doesn't swing down far enough...my only thought on the matter.  Your defense of not wearing a mask under the hood speaks volumes for thinking of the kids' safety from a mask catching fire!
Reply:I was fine my OSHA for no TP in bathroom. Had 2 guys running a 400 ton press break and they both had head colds so took out and set at press break. They both new where the TP was sitting.  OSHA was not worried about paper cuts in butt or fingers in the break dies.FYI the fine in 1989 was $2,500 for no TP in bathroom Dave
Reply:Never hire any one and OSHA has no reason to see you. They stopped because no employees to be in danger or fine you.Dave
Originally Posted by 123weld
lol,lol.    parts look nice - and the kids get an early lesson about osha
Reply:Shame that people are so dumb these days that you've gotta put a guard on the grinder to keep them from licking the wheel. I bet it would HURT with that wire wheel!
I don't have guards on my go-to bench grinder. They are DANGEROUS if you use a wire wheel or a buffing wheel. Stuff gets sucked in, spun around in the guard, then flies back at you. I took the tool rests off, too. I just free hand sharpen my twist drills. Works fine.Sent from my Lincoln Buzzbox using Tapatalk
Reply:Nice job Dave but GD, what a waste of time. Next you'll have to leave it unplugged and put a pull cord on the unused wheel to get it to rotate. Least that way they won't get both hands in there. Crap, when i went to trade school (shortly after they invented electricity)  the instructor took the side cover off so we could use the side of the wheel..........Mike
Reply:My wire wheel is on an open motor with an arbor, and I like it that way for wire wheeling, but I have actually thought about building a guard to stop the flying wires from coming towards me. One of those trade offs for which there is no easy answer. Nice work on the useless guard by the way.... likewise I have never seen one like that...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:I have a buffer and just put board/shelf over top of buff and stops flying buff.Dave
Reply:I was wire wheeling a plastic injection nozzle tip to get it clean for job change over many years ago when the wires grabbed the tip and threw it back out at me.  Hit me in the middle of my upper belly just below the ribs.  It instantly knocked the wind out of me and I had to take a knee a moment later.  That spot on my belly was tender for several years after.  Learned the hard way not to stand directly in line of Fire :/Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:You gain more knowledge that day. Dave
Reply:That is very true.In my case I would be sue my self. But big question is can you count to twenty on your hands and feet.Dave
Only if you live to remember and help others from doing the same thing.  The company did not properly train employees on safe use of the grinder so technically I could have sued.  Since I could still do my job I saw no reason to sue.
Reply:nice guard. I tend not to run guards as they aren't thought out very well, but that one is. and will if the wheel shatters affrord some protection.anyone ever had a wheel shatter when at speed? well, put it this way, if you didn't put your brown pants on that morning you have now!!
Originally Posted by ghost_walker
nice guard. I tend not to run guards as they aren't thought out very well, but that one is. and will if the wheel shatters affrord some protection.anyone ever had a wheel shatter when at speed? well, put it this way, if you didn't put your brown pants on that morning you have now!!Did you use your OSHA safety gauge and check the measurements?
Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:The grinder looks great.But it was for a school and teachers will have there say plus OSHA. The best news is you makes a lots of money with everyone thinking the best way. I do like you OSHA Drawing. Dave
Thank you
I've never seen one shatter - but I'm sure it's not pretty
Reply:The time I a grinder wheel broken is a employee drop the a 7" angle grinder off the roof. Dave
I've never seen a bench grinder wheel shatter (not when it's on the machine, anyway
). I know people who've had grinding wheels on angle grinders explode, though. Sent from my Lincoln Buzzbox using Tapatalk
Reply:Those guards are nice, real nice, and you're correct, they're worthless, I don't remember what the clearance spec is but 1/4" seems to come to mind, they somehow fell off of my 2 home grinders, and you're 100% correct about their quality & cheap tin, they wouldn't stop or even slow down a serious wheel disintegration. Good job on your design.NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINELET'S GO BRANDON!"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
Reply:We did get trained a bit after my incident though.  Was banned from grinding Aluminum tools on the grinder stones.  I've never seen it and thank God but apparently Aluminum will flow into the stone and cause it to be out of balance and or cause it to explode.  I'll take it as good advice not to use aluminum on any bench grinder stone.Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:Not a bench grinder, but here's a picture that showed up on another forum of a guy who got hit with an exploding angle grinder disc.  I had another picture of his hand right after the cut with it laid wide open...didn't save it.
Reply:Was he wearing gloves and what size was the grinder?Dave
I heard about that one time, many years ago.  Never saw the aluminum actually explode a wheel though.Last week some students ground aluminum on the large grinder.  The aluminum did get very stuck to the wheel and caused steel to bounce when ground.Using the wheel dresser cleaned it right up.  Grinding on steel did not - I thought it would. Edit: just remembered - the inspector told us that the aluminum gets forced into the wheel, and then when ground later the aluminum can heat up and expand, cracking the wheel.Thus, fragmentation and blowing up.
Reply:You have to grind steel to remove the aluminum from the stoneOr it will though chucks of aluminum at you . Dave
My oldest brother Bill was a machinist by trade and he told me it was common knowledge in the trade to never use aluminum on bench grinders.  Your explanation makes perfect sense.
Reply:Broken carbide bits work for dressing wheels. You DO NOT want to breath carbide dust, though. I do a LOT of **** that I shouldn't, though.
Reply:Hate to use my diamond dresser on aluminum. Dave
Much easier and faster to use a stone dresser.  Cleans it right up and should eliminate the problem of heating up the aluminum to an expansion point that the wheel can't handle.
Reply:Maybe we can just take instead of yesterday's Dave
Reply:If ya think OSHA is nutz!   They aint nothing compared to MSHA, they cover the Mining industry,  2-4 surprise visits per year, your not allowed to tell other miners the the inspector is on site, but we have program for that!    LOL.     A MASHA inspector will fine the company of individual contractor just to justify his existence.  Any time one shows up, the contractors roll up and take a day or two off.    Basically a government agency that fines you to make you safe!   LMMFAOWe've done so much, for so long, with so little. Were now qualified to do anything with nothing !
Reply:[QUOTE=welding1;8860557] MSHA, they cover the Mining industry,  2-4 surprise visits per year, your not allowed to tell other miners the the inspector is on site, but we have program for that!    LOL.   /QUOTE]id like to know how they figure there above the "first ammendment/constitution"
Reply:Sorry to here about cancer What type of cancer?Dave
Originally Posted by farmersammm
Since the cancer diagnosis, I'm using an N95 for all grinding, and welding.  Didn't use any protection for 20yrs.  Not saying that these particular hazards caused the cancer, considering I also smoke..................but a combination of the welding hazards, and smoking, could have been the trigger.  I'll never know, but I figure I'll try to cut out at least one hazard, and cut back very seriously on the other.The greatest effect I've seen..........no more hacking up crap, or blowing my nose, and having it come out black.  That mask made a huge difference  when grinding/welding
GMT+8, 2025-12-18 16:47 , Processed in 0.132496 second(s), 18 queries .
