Question: using adjustable gate hinges correctly
发表于 2022-5-19 11:02:28 | 显示全部楼层 |阅读模式
Hey guys, it's been awhile.  I've got a question about hinges that I couldn't find the answer for.  I'm replacing standard barrel hinges for a 12' total split gate (6' a side) made out of 2" x1/8" steel tubing.  I had my driveway repoured and the grade underneath is now different.  My original hinges lasted fine for about 8 years but I always wanted adjustability in case either of the walls move a bit.  I found these barrel/j-bolt hinges:https://www.amazon.com/Hinges-Adjust...29&sr=8-5&th=1They look like an easy fix but I have two questions: 1) how can I install them so that someone can't put a 2x4 underneath and simply lift the whole gate off the hinges?  With the current barrels, I switched the sides as a trick I learned on here2) will these types of hinges have problems with rain getting into the hinge body? doesn't look like a complete overhang of the hinge body so water could get in.
Reply:you can tack a tab into the post above the barrel side of the post.yes they are susceptible to water, freezing, seizing and shearing if not maintained. sounds like a personal gate.  keep it greased and you should be fine.  100 percent of the hinges I have replaced were never greased after installation,  thus failure.
Reply:1) how can I install them so that someone can't put a 2x4 underneath and simply lift the whole gate off the hinges?
Reply:.Just out of curiosity, I looked more closely at the ad. Looks like one pair of hinges goes for $29.99. Clicking on the box for two pair gives me $166.62; three are $249.91 and four are $333.22. If one pair is $30, would not one expect to get 11 or more pairs for $330? What gives??? Screenshots below to document this.------------------------------------------------------------
Reply:Turn one of them upside down?
Reply:" Just out of curiosity, I looked more closely at the ad. Looks like one pair of hinges goes for $29.99. Clicking on the box for two pair gives me $166.62; three are $249.91 and four are $333.22.If one pair is $30, would not one expect to get 11 or more pairs for $330? What gives??? Screenshots below to document this."Some people have found that companies simply order on quantity, and never look at the price.So, they simply offer a higher quantity, at a greatly inflated price.When the order comes in, the reseller simply orders the Quantity 1 times the quantity ordered,, and pockets the greatly inflated difference.There are offers like that all over Amazon.
Reply:My preference would be to put the barrel on the gate.  You will get the vertical support of both hinges and the benefit of the rain catcher down.  If I were going to flip, then I would use a third hinge or a tab.If you have to adjust a steel gate, then I would identify where the sag is coming from.  Is the diagonal flexing, the post flexing, the post moving, growing heaving,  opener causing movement….?
Reply:Built a set of shop doors on my sons shop a few years back.  You need good support for posts, these are great for leveling the doors.  Will go back look for the picturesRetired Old GuyHobart 210Lincoln AC/DC 225/125 Tombstone Evolution 14” Saw
I did this for a simple gate I welded up on the deck to keep dogs off…Normally I would turn one over but this was a non security set up so went easy.
Reply:Thanks for the replies. This helps a lot.
Originally Posted by tapwelder
you can tack a tab into the post above the barrel side of the post.keep it greased and you should be fine.  100 percent of the hinges I have replaced were never greased after installation,  thus failure....My preference would be to put the barrel on the gate.
GMT+8, 2025-12-18 19:23 , Processed in 0.094758 second(s), 18 queries .
