Wiring an auto crane
发表于 2022-5-19 11:02:26 | 显示全部楼层 |阅读模式
Anyone know how to wire an auto crane? I don't know where to even start I don't know where to hook up the positive and ground.Any help would be appreciatedI've got one wire coming out of the base of the crane
Sent from my SM-G973U using Tapatalk
http://www.philswelding.com
Reply:That one wire out of the bottom should run to the battery positive. Everything else in the crane should be self contained. At least that's how mine are.ETA, mine run through a 150 amp circuit breaker near the battery source just in case that cable gets shorted under the truck.Last edited by 12V71; 2 Weeks Ago at 06:04 PM.
Reply:Is there an on switch? Or is it always "on" just waiting for a button to be pressed on the controller Sent from my SM-G973U using Tapatalk
Reply:I'd want a key switch on a solenoid relay, don't want the neighborhood kids playing with it.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:Here i a link to the manuals page fore AutoCrane cranes. You should download and keep a copy of the correct manual in your truck, OSHA and insurance required. There are wiring schematics in the manuals. A LC40 connector on the power lead is a quick and simple way to disconnect power when not in use.https://autocrane.us/manuals/legacy/Mike
GMT+8, 2025-12-18 16:42 , Processed in 0.097921 second(s), 18 queries .
