Powered Hacksaw
发表于 2022-5-19 11:02:26 | 显示全部楼层 |阅读模式
I bought this powered hacksaw several years ago. Mounted it up on a roll around stand. Played with it a while till I got it all working right. It's kinda neat, but I figured I wouldn't use it that much. Well, I have surprised myself by how often I find myself using it. I put an automatic cut-off switch on it and can turn it on and walk off. Just need to go by and dribble some oil on now and then. I plan on an automatic drip oiler one day. It has become pretty handy and cuts very straight.Craftsman 230/140 AC/DC   Miller HF-251D-1Millermatic 130   Linclon 40 amp plasma cutterHypertherm Max 20    O/A cutting and welding stuff5HP Ingersoll air compressor
Reply:I look hacksaw blades they lot cheaper than bandsaw blades. Just need to build one but have a band saw .Dave
Reply:Boy that brings back memories.  I build one like that back in the 70's there was one shown as a construction article in a magazine.  A welder from across the street copied it for his home use.  The big thing I found was do not oil the blade, it will clog it up, the chips need to fall free.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:We had one of those old dinosaurs in the machine shop up until about 93, I think it took a 30 inch bimetal blade, it had a coolant pump and used soluble oil and flooded the cut to wash chips out. We replaced it with a nice bandsaw, the new saw would cut across a 40 inch wide piece, the blades wer something like 28 ft 6inches or so, it seemed huge, but was a nice saw, it would cut within .006 -.008 on a 16 inch HERCALLOY TUBE.NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINELET'S GO BRANDON!"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
Well. Learn something new every day, if you pay attention. I did some reading on the magic internet and found much information about dry vs oil on powered hacksaws. Looks like the "DRY" side wins. I am going to run it dry and see how blade life changes. Thanks!
Originally Posted by rexcormack
When the blade gets dull you can turn it around because that type of saw will cut on the push as well as the draw!
Get twice the life out of the blade!
Reply:I have the same saw. Not particularly fast but can be run unattended.Mine is branded “Craftsman “ but I think the same saw was sold underother names.Something about old reciprocating metal working machinery I like.(I have an old South Bend shaper too.)Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Covel Manufacturing (Chicago, Ill  Benton Harbor, MI):http://vintagemachinery.org/mfgindex...l.aspx?id=2115Sears Craftsman power hacksaws (look under All Machine Types > Hacksaw, Power):http://vintagemachinery.org/mfgindex...x?id=222&tab=4Last edited by Denis G; 1 Week Ago at 07:51 AM.
Reply:Good memories. First shop I worked at had two auto feed hacksaws. They'd be set up at knock off time every day for repetition work with full length bar stock and in the morning they'd be all cut up. During the day  one guy full time keeping them running. They never stopped.They were slow and steady but cut dead square and didn't throw sparks or shards so were safe.Last edited by Woznme; 1 Week Ago at 07:24 AM.
Reply:I really like to use it every chance I get. I enjoy just watching it do the work!Craftsman 230/140 AC/DC   Miller HF-251D-1Millermatic 130   Linclon 40 amp plasma cutterHypertherm Max 20    O/A cutting and welding stuff5HP Ingersoll air compressor
Reply:I like cost of blades.Dave
Reply:Bud tried to give me one a while back.  Said it was in his way and he wanted it to be in my way.www.urkafarms.com
Reply:Speaking of hacksaw‘s, this is a handy little bugger for tight spots.
Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:I have that too.Still have a old fashion hacksaw on my cart for fast cutting jobs.Dave
Originally Posted by Lis2323
can you still buy those?  i like the variable   stick out capability.
Sent from my iPhone using Tapatalk
Reply:That old power hacksaw may be slow, but the 2x HF sized bandsasw I have had aren't' worth a cent.Crooked cuts, throwing blades.Maybe I just have to set it right, but I have never found the proper working trim.
I have a light duty version of the above saw, and it's been a good machine. I don't use it much now that I have the bandsaw, but it has it's place if I'm cutting something that might wreck a blade. It came with an industrial blade, but I don't see them around anymore so I just put decent quality bi-metal blades in it. I also have a Chinese version of John's single blade holder but they come in plastic now. Every tool has it's place...
The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Looks great and box 50 blades only $5https://www.harborfreight.com/12-in-...-pk-60284.htmlDave
Reply:I have seen those saws in metal suppliers, but they are not used much. when I go there to pick up material I usually ask for the dull blades (they scrap them) to make shop knives out of them. I just cut the profiles and grind the bevels without overheating them so I can avoid to heat treat them. I drill a few 3mm holes with solid carbide bits for pins and slap some hardwood scales with epoxy. Done! I am talking about the aforementioned industrial blades (thick and wide).If I owned one of those saws, I will try to refurbish it a bit, at leas wire brush/sandblast, degrease and a lick of paint. It would be cool to have arround.Mikel
Reply:They work well but there is a very good reason they aren’t used much anymore. There are just too many modern options that are more efficient and versatile. Here is a cheap import I refurbished.
:I think I have 4 power hack saws. 3 are converted from line shaft drives and 1(Racine) was always a motor drive. None are painted but if someone would like to see them painted, they have my permission.---Meltedmetal
Reply:Sounds great Any photos?Dave
Reply:It's hard to have a favorite hacksaw, but this old classic would be my choice. Spends most of it's time hanging around under the welding bench these days...
Forget Harbor Freight... there's a better class of Chinesium out there. I doubt I have much more money in my 5x7 King than you spent on those 2 you didn't like, and it's been a new favorite tool of mine.
Reply:Pretty much the identical machine... I never used the coolant system either. The original owner never used it much so I think I might still be on the original blade... got a few bi-metals that are going to have to go into it soon though.The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:It looks like the old style of the 4x6 saw?The only found was getting blades that did not break. The break long before wearing out. I drawings some were of Popular Mechanics hacksaw using standard blades. Dave
Same. I bought this one new in 1999 and sold it recently when I found a used Ellis.
Only thing I did was check adjustment, rip out the coolant system and buy quality blades. Sent from my iPad using Tapatalk
Reply:Just case you need a new hacksaw from China https://m.made-in-china.com/product/...725437132.html
They sure aren't cheap. I like how some of the lower end ones are listed as "negotiable".
Reply:Looks great 👍 I get tire of buying bandsaw blades that break at high price. Dave
You will note there is no OSHA presence in my shop. The one sitting in front of the Racine is the first one my father bought in the mid 1930's. I have one other one but it is buried even deeper. As mentioned earlier if anyone would like to see them painted and polished they have my permission to come here and do it.
Looks great
GMT+8, 2025-12-18 16:57 , Processed in 0.103818 second(s), 18 queries .
