JB Weld ?
发表于 2022-5-19 11:02:25 | 显示全部楼层 |阅读模式
It says set in 4 to 6 hrs  and then overnight above 40 F.  I dont have a sheet for it I wonder how much temp accelerates it, both set and cure..  I just put a second gob on, dont believe I disturbed the set, in a while I want to flip and pot another gob on the other side. I am going to put in front of a register.  Will it fully cure in 12 hrs at 100 degrees?Last edited by Sberry; 03-22-2022 at 06:06 PM.www.urkafarms.com
Reply:Yes . .
Reply:Yes. Should be rock hard in that time and temp
Reply:Yes it should be good 2 go in 12 hours. If it's real cold when using it, I sometimes heat up the puddle with a heatgun while you are mixing it.   it help it flow nice.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:It something that I had to remove with torch. It has a great smell when torch is used a skunk has a better smell 😉.  Dave
GMT+8, 2025-12-18 16:46 , Processed in 0.135289 second(s), 18 queries .
