Printer for truck
发表于 2022-5-19 11:02:24 | 显示全部楼层 |阅读模式
It looks like it might cost,,, what's an economical way to print a page or 2 in the work truck?www.urkafarms.com
Reply:Use a inverter 12 volt DC to 120 volt ac and use a standard printer . It is cheaper than the portable printers. Dave
Reply:Text or email?
Reply:Or spend $250.00 for a portable printer.https://www.walmart.com/ip/Canon-PIX...mpaign_id=9383Dave
Reply:Depends... if you're printing greenbacks you could be making money...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:We are using a van, might be able to rig up a ceilinjg bracket for something small made for office,,, basically disposable etc.www.urkafarms.com
Reply:They make portable but the cost and supplies are high cost. I can buy a office printer under $100.00 and the supplies are a lot cheaper too. There also a few office printers than run on 12 volt power supply hard to find too.Dave
Reply:Here is the inverter I usedCan’t remember which printer it was but it was single pagePut a piece of paper inHit print and get one copySo on and so on.
Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Now to find a RadioShack.  Dave
Reply:I have to travel 50 miles to small town to find RadioShack. All my electronics purchase are on line now.Dave
Originally Posted by CAVEMANN
We still have an electronics store that says "RADIO SHACK of the signage. They even have some radio shack supplies/stock left.
GMT+8, 2025-12-18 16:44 , Processed in 0.091339 second(s), 18 queries .
