I just finished making a removable work surface for the hydraulic lift table I bought a while back
The top is 48x96. I used a 5/8 steel plate crop I had left over from my last welding table build and 3/4 birch plywood good both sides.
It has 36 of vertical travel with a lowered deck height of 12.
The benefits of a height adjustable work surface should be pretty obvious to those of us over the age of 50.
Sent from my iPad using Tapatalk:
Reply:that looks really sharp!! I call my HF lift table with 900lb cap. my little helper. I've found lots of different uses for it. The jack eventually started leaking under load so I rigged up a chain and hook in the scissor linkage so I can set the load on the chain to take pressure off the jack. It doen't leak off fast, just leaves a little puddle on the floor.Ol' Stonebreaker "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:That is HEAVY DUTY!!!!! I have an electric #450 lift table for my main welding station, and LOVE being able to adjust the height from 26" to 42".(I am DEFINITELY over 50)
Reply:I downloaded many videos about guys making lift tables for their shops, here is an example many others on YouTube too. Changed can be made to make it as heavy duty as you want.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:I have limited space, so I use this as a lift table.. Although a dedicated one like above is real nice too.
Prices on all this stuff is stupid now, and finding anything that works has a lot of value.
Esab/Lorch ET-220iEsab 160i caddyEsab CV353Thermal LM-200/ Lincoln feedersThermal 60i- 3phase Pak 50Thermal 35CThermal 15cINE 1500 Klutch 220iBlue Demon/140 msi/90sti
Reply:I like your Pneumatic jack, I had airbags on a street rod, we also used big air bags to lift equipment for moving, amazing how a small PSI will lift. They were like Hovercraft one man could push very heavy equipment with ease.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:It's handy for sure.. Still China made, but a couple of levels above the cheap models.Warehouse deals at $238.90 . I have not used my Heinwerner or Lincoln Floor jack since I got it..https://www.amazon.com/ESCO-Bladder-...7S8RTVWN&psc=1
Reply:I've had good luck with Vevor products. this jack is $200 cdn free delivery https://www.vevor.ca/floor-jacks-c_1...p_010268354817
Sent from my iPhone using Tapatalk:
Reply:I used that one, but longer handle/ different version.. They work fine but the cones inside stick sometimes, and also the jack can tilt way more than the esco or better quality units. Clunky to use but works. Best to spend more on these type of things, unless just for limited use.The above car was on a slope, and a cheaper unit jack would of been listing all over the place.Last edited by Brand X; 2 Weeks Ago at 08:32 PM.Esab/Lorch ET-220iEsab 160i caddyEsab CV353Thermal LM-200/ Lincoln feedersThermal 60i- 3phase Pak 50Thermal 35CThermal 15cINE 1500 Klutch 220iBlue Demon/140 msi/90sti |
