Starting mobile rig
发表于 2022-5-19 11:02:21 | 显示全部楼层 |阅读模式
Howdy all, I’m not a licensed welder but work in agriculture and use one often. Been kicking around the idea of starting a mobile rig doing mainly ag related repairs along with building pipe fence. I’m not where I need to be yet in order to charge folks. My question is broad but, what boxes or criteria should I be able to meet in order to pull the trigger on starting a little rig?  Thanks in advance!
Reply:The only time you need a license is welding on buildings and fencing. Dave
Reply:You would need to check your state contractor board, I am in California. But most states is not bad as California. If I only did repair I would made more money.  Most building work is quoted with lots of rules it takes the fun out of welding. Dave
Thanks Dave. Is that just for residential fencing?
GMT+8, 2025-12-18 17:00 , Processed in 0.098034 second(s), 18 queries .
