Are these welding rods?
发表于 2022-5-19 11:02:19 | 显示全部楼层 |阅读模式
I have a bunch of these hollow rods in different sizes.  Are they for welding?  It was bunched together with welding items at an estate sale.Thanks!
Reply:Not real sure since it has been a long time since I worked with divers, but I think that is a cutting electrode for under water use. Takes a special stinger with oxygen pumped through the rod and requires around 5 or 6 hundred amps to operate under water.
GMT+8, 2025-12-18 16:44 , Processed in 0.093508 second(s), 18 queries .
