lincoln 305g problem
发表于 2022-5-19 11:02:18 | 显示全部楼层 |阅读模式
i recently aquired a lincoln 305g welder which runs fine, generates 110 and 220 power but wont weld. i understand the control board is prone to failure on this machine and would appreciate any help on proving if this is the problem as replacement boards are very expensive. thanks
Reply:https://www.lincolnelectric.com/en-z...r-manuals.aspxNeed to post your code #
Reply:[QUOTE=guajilloweld03;8861904]https://www.lincolnelectric.com/en-z...r-manuals.aspxNeed to post your code #
Reply:yeah, thats a problem also. i cant find code or serial #s on machine anywhere.
Reply:finally found a sticker inside the machine with info. code#11794
Reply:Check for any loose or bad conections, test the bridge rectifier and capacitor, call Lincoln tech support.
Reply:will do, thanks!
GMT+8, 2025-12-18 19:12 , Processed in 0.100733 second(s), 18 queries .
