Ehab Sentinel A50 dead?
发表于 2022-5-19 11:02:18 | 显示全部楼层 |阅读模式
Hi haven’t used my helmet in a couple years since finishing my last project and went to use it after it was stored in bag , I get no display and super brite when I strike the mig to weld. I measured the battery voltage and both were 2.4 and 2.5 volts , is it just the batteries that are dead?LynnMillermatic 211
Reply:What size battery? 24-25?Batteries are cheap.....Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunModified Lincoln 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc GougingEverlast 62i Plasma CutterIngersoll Rand Type 30 14hpInstagram: #Freebird Welds
Reply:after a couple years, yes more than likely.
Reply:Thanks guys , I’ll head out and find a couple battery’s , threw me off when I read the voltage at 2.5 volts, figured there’s lots there still.LynnMillermatic 211
Originally Posted by tadawson
IIf it's a lithium button cell like a 2032, anything below about 3 is stone cold dead . . .
Reply:I have two of these hoods and they don;t like to sit for long periods, they will kill batteries. I always take the batteries out of the one I don't use much, because 2 months without use will kill the batteries on it. Other than that, they're great hoods, and if used weekly or daily the batteries will last no problem. Very strange.Murphy's Golden Rule: Whoever has the gold, makes the rules.
Reply:I have a esab sentinel a40 and I leave it in the open so it gets some light and it has worked for years.  I always keep a pair of spare batteries just in case though.
Thanks, so it wouldn’t make a difference just to leave it hanging in the window?
GMT+8, 2025-12-18 16:46 , Processed in 0.070209 second(s), 18 queries .
