Ranger 305G volt meter not working
发表于 2022-3-19 15:51:19 | 显示全部楼层 |阅读模式
Hello!I stopped by to help a friend with a Ranger 305g efi that he had a engine problem with, and we got it running fine, idles up and down has proper 120 / 240 volt output and appears to have power at the cable terminals. What isn't working is the voltmeter. Swapped displays and still get nothing on the voltmeter, wire connections appear good as well. The code is 12206. Just wondering  if anyone has any tests we could do to confirm a board problem?Thank you in advance for your suggestions!If anyone has any Kohler questions, I am pretty good with those.
Reply:Does machine have to be set to CV (wire feed) mode for voltmeter to work?Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
GMT+8, 2025-12-18 19:12 , Processed in 0.105971 second(s), 18 queries .
