Ck Worldwide - Glycol coolant torch performance & Good technical support
发表于 2022-3-18 15:51:24 | 显示全部楼层 |阅读模式
Last night I shot an email off to CK Worldwide asking if using 50:50 water:glycol (propylene or ethylene) affects a torches current rating. The president of CK Worldwide got back to me this morning and confirmed that, "The mixture does not matter. You should be getting about a quart per minute through the system not to exceed 60 psi for optimum cooling." So, from the horses mouth, CK torches can be used with water or glycol mix with no derating of current capacity.I have to give props to CK for having a higher-up respond to a technical inquiry in under 24 hours.
Reply:Pretty much what torch coolant is. Glycol in deionized water. For about $12 yr I stay with pink torch coolant instead of making my own.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
. For about $12 yr I stay with pink torch coolant .
Reply:Last time I bought it was from Airgas. I haven't looked for the slip but I recall about $28. plus shipping, plus fuel surcharge, plus HAZ MAT fee, plus tax.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Originally Posted by John T
And with that let’s head right into a BS coolant debate. Im out.
Reply:Don't get me going about air gas. The so called Mgr lied to my face.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
GMT+8, 2025-12-18 16:47 , Processed in 0.102000 second(s), 18 queries .
