Why The Tire Scumbag Retired
发表于 2022-3-18 15:51:24 | 显示全部楼层 |阅读模式
  Another parked tire delamination.
  Absolutely no carcass thickness over the radial plies.  Pure crap.  And not cheap.
  5yr old tire with less than 500 miles on it.Word is the Fk retired...................I'd wager he had to quit the biz because people quit buying his trash.
Reply:Looks overinflated.
Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Looks like as long keep it 75 you at less 2,000 miles. It looks safe Dave
Reply:I had a triaxle 9 ton. Only heavy duty tire I could find in the size were Blue Star (Chinese tire). Max load capacity at max inflation was 110 PSIG. Less than a year, 300 miles all 6 blew out the sidewalls. Tire dealer blamed me. I had asked for tubes as the trailer had a long history of losing air. I had to add air to tubeless each trip. I figured tubes would solve that problem. Dealer claimed tubes kept them from dissipating heat.Newer trailer has a different size tire, same load, again six wheels. 4 years no failures. Yes, these have tubes also.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:These ones are radials and starting to crack too so I just ordered replacements. Trade you bills.
The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
GMT+8, 2025-12-18 17:06 , Processed in 0.078003 second(s), 18 queries .
