Ramp bracket
发表于 2022-3-18 15:51:21 | 显示全部楼层 |阅读模式
Hi,I am a beginner welder.  I have a 200amp mig/stick.  I want to load my 4000lb skidsteer in the back of my F550, I bought 12' aluminum ramps for this application. The deck is 46" off the ground. I need to make ramp brackets, similar to the ones on my trailer (pictured).What thickness is appropriate material? I was thinking 3/8s...I was thinking to use angle iron and cut notches out on the bottom(for water run off).Or would it  be better to use flatbar and just make brace it.
Sent from my SM-G950W using Tapatalk
GMT+8, 2025-12-18 16:58 , Processed in 0.199853 second(s), 18 queries .
